Type: Citizen band/Freeband/Export/Amateur transceiver
Frequency range: 26.?-28.? MHz
Channels: 240
Mode: AM/FM/SSB
Frequency control: PLL
Power output: AM: ? W
FM: ? W
SSB: ? W
Sensitivity: N/A
Selectivity: N/A
Image rejection: N/A
Voltage: 13.8 VDC
Current drain: RX: Max ? A
TX: Max ? A
Dimensions (W*H*D): ? mm
Weight: ?
Manufactured: xxxx-xxxx
Other:
Related documents:
informacji więcej brak na jego temat
Zodiac Tokyo
Zodiac Tokyo
- e tam .Chyba Norwey & Filand by Zodiac . www.rigpix.comGRAND pisze:to jest ponoć jackosn tylko w wersji japońskiej
