sirio cruiser 2010
sirio cruiser 2010
Features:
• Designed to work without Ground Plane
• Perfect protection against the worst weather conditions
• Supplied with white coaxial cable RG-58 C/U directly connected
• Stainless steel hardware
• High quality white fiberglass conic whip
• 180° inclination and adjustable whip
P/N 2301220.83 CRUISER 2000
Electrical Data
• Type: CB base loaded
• Center Frequency: 27.185 MHz
• Impedance: 50Ω unbalanced
• Radiation (H-plane): 360° omnidirectional
• Polarization: vertical
• Bandwidth at S.W.R. 2:1: 5600 KHz
• S.W.R. at res. freq.: ≤ 1.2:1
• Max. power:
15 Watts (CW) continuous
50 Watts (CW) short time
• Feed system / Position: Transformer DC-ground / base
• Cable length / Type: 5 m / white RG 58
• Standard mount: "M-8" NY
Mechanical Data
• Materials: Nylon, Glass fibre, Chromed brass
• Height (approx.): 1505 mm
• Weight (approx.): 720 gr
- truckmaniac
