SPECIFICATIONS
* RX frequency range: 0.100 to 1,299.995MHz * 1
* Mode: AM, FM, WFM, WFM stereo
* Antenna imp.: 50 ohms unbalanced / SMA
* Battery voltage: 3.6Vdc to 6.0 Vdc
* External DC power source: 4.5V to 16Vdc
* Battery consumption: 150mA nominal/ stand-by 75mA/ battery-save ON(1:4 cycle) 39mA
* Operating temperature: -10 to 60 C or 14 to 140 F
* Frequency stability: +/- 5 ppm at operating temperature range.
* Dimension without projection: 56(W) X 102(H) X 23 (D) mm
* Weight: 145g with Ni-MH battery pack and a rubber-duck antenna
* RX System: Triple super heterodyne
1st IF: 248.45MHz
2nd IF: 38.85MHz
3rd IF: 450KHz
* RX selectivity:
AM/FM : -6dB/12KHz or over -60dB/30KHz or less WFM : -6dB/150KHz or over
* RX sensitivity(Typical):
FM / 30 to 550MHz : less than -3dBu/12dB SINAD, 550MHz and up: less than 0dBu/12dB SINAD)
WFM / less than 13dBu (12dBu SINAD)
AM / 0.5 to 1.62MHz : less than 17dBu (10dB S/N), 1.62MHz and up : less than 5dBu (10dB S/N)
* AF output: Max 220mW or more (8ohms)
